I am using an ESP32 from Adafruit as a Wi-Fi telemetry. Using DroneBridge, I can configure and connect with my drone through QGC. However, I want to connect the ESP32 to my wifi (Wi-Fi station mode) and my laptop to the same wifi and use it from QGC. How can I do that? Thanks in advance.
DroneBridge for ESP32 just received an update. It is now possible to connect to an existing WiFi network with the ESP32
I will try that out and let you know. Thanks for the update.
Hi I flash my esp32 with dronebridge esp32 but after that the manual says connect to the WIFI whereas I am not having any WIFI name dronebridge.This is from where I am referring ESP32 WiFi telemetry — Plane documentation
