I don’t have any personal experience with it, I just read it here on the forum.
This looks like worth a shot (Hi Reinhard ^-^):
For more examples search the forum for “LTE telemetry”
Dragonlink also supports full (two-way) MAVLink telemetry together with the RC link. ELRS currently doesn’t support MAVLink, if I’m not mistaken (please correct me if I am). Crossfire theoretically does but I didn’t have much luck with it last time I tried it.
@Indie_Hacker mentioned that only normal telemetry is planned. ExpressLRS is good for that. With the branch “mavlink-rc” Mavlink will also work, but it will take some time. LTE is also a possibility.
Dragonlink is not bad, but 3.5 years no more updates and Mike doesn’t have a programmer for it anymore … the project is dead if you ask me.
I would take ExpressLRS, it is also much cheaper and can be bought at any time.
The easiest way is with analog video on 1.2/1.3 GHz. With digital video (Walksnail) I haven’t gotten over 40 km so far.
Setup tips for 1G3 video can be found here. You will soon realize that the selection has become small. I can only recommend equipment from RMRC and antennas from TrueRC.
That’s good. At least we have a very clear requirement: ~50km long range flight, mainly focused on RC/Video link.
When Video link is broken, it’s hard to recover, especially long range, even if analog VTX when turn a round the antenna is blocked (partially blocked) by battery or companion computer etc.
When video link is down, it’s impossible for FPV pilot to operate the drone. Then if telemetry is OK, we can still navigate the drone(RTL or smartRTL is NOT that smart actually, maybe some expert with carefully setup for rally points might to the smart thing) from MP or QGC and know where it is. If crash, we can know where it crashed ( last know position will be send out by telemetry.
That’s the advantange of dual link control. And of course, low power telemetry or PCB antenna??? is useless for such long range flight.
– EDIT
BTW, mostly VTX works on 5.8G/2.4G/1.2G etc, and RC link works on 2.4G/915M/868M etc. Some known telemetry module works on 433M/868M. In the same situation, low frequency is much more likely to transimit far away.
Maybe switched to 4G LTE module is a good choice for civilian usage: vdeo and telemetry( for long range) Ah~~~~ that’s the DJI drone.
Very good points. I will dive deeper to learn more about MP and QGC stuff, and probably re-consider my requirements regarding telemetry.
First I thought I could do LTE. But now I figured is probably not an option for me due to bad coverage in the area of flights, most likely there is no mobile signal at all
