Why EKF2 is missing in 4.1.0?
Im just installed px4flow through i2c port.
And use TFminiS lidar goes to telem2 port.
On status, both works fine.
(Lidar range good)
(Opt_m_x and opt_m_y also changing)
Then im about to try my first flight.
The instruction is
For EKF2, set [EK2_GPS_TYPE] = 0; for EKF3, set [EK3_SRC1_VELXY]= 0 (we don’t want the optical flow being used by the EKF at this stage
But EK3_SRC1_VELXY is just available on 4.1.0
While 4.1.0 make all EK2 parameter is lost
Please help me for the solution.
Thank you very much
It is missing because the board you are using has limited memory. Something had to be removed to make it fit.
Update Mission Planner to the latest beta.
I use missionplanner 1.3.75.1
then HELP → Check for beta updates.
and it downloads and updater pop up.
then i sucessful update the missionplanner with beta updated.
then i re-install quad firmware with 4.1.0
but still ek2 is missing.
Any idea how to make this ek2 appear again?
thank you
You should use EKF3 instead.
Hello thank you for your reply.
Anyway im just following the px4flow instruction.
For first flight i need to do :
EK2_GPS_TYPE = 0
EK3_SRC1_VELXY = 0
(we don’t want the optical flow being used by the EKF at this stage)
So we can just ignore EK2_GPS_TYPE = 0 ?
Note : actually px4flow already active.
Opt_m_x and opt_m_y value keep changing
Which is good.
Sonarrange also good.
But im not able to RTL when no gps lock.
So i assume my px4flow still something wrong.
Thats why i start follow ardupilot instruction and found ek2 is missing on 4.1.0
Use EK3_* instead of EK2_*
So from
EK2_GPS_TYPE = 0
EK3_SRC1_VELXY = 0
Just simply change into
EK3_GPS_TYPE = 0
EK3_SRC1_VELXY = 0
And px4flow will works?
If i just use pixhawk orange cube.
Wont have this problem ?
There is no problem. All flight controller have EK3 enabled as default with 4.1.0. EK2 is no longer an available option on some boards with limited flash unless you do a build with the Custom Firmware Builder.
