I manually set the following parameters:
Q_ENABLE =1
Q_FRAME_CLASS=7
Q_FRAME_TYPE=1
Q_TILT_ENABLE=1
Q_TILT_TYPE=2
Q_TILT_MASK=3
You may need to restart before the parameters take effect.
Have you pressed the arming switch?
Thanks! This problem is solved.
Recently I want to use px4 firmware to implement VTOL. Do you know if there are parameters similar to Q_TILT_FIX_ANGLE function in PX4 firmware?
We don’t follow the PX4 flight stack. You are better off describing what you are looking for rather than referencing PX4.
