I am looking for a compelling argument to build my industrial rover around BeagleBone Blue. Is there one?
And what is beagelpilot? A modified fork of ardupilot that could be discontinued?
I’m have the same question. Bump!
the BeagleBone Blue is not yet ready for a full Rover implementation.
Its missing the quadrature encoder-decoder (QEP) and brushed PWM using the internal PRU.
These feature are needed for the new Rover release to work as a hobby grade vehicle.
Industrial vehicles are generally using more advanced motor controller that have built-in PID and ramp profile based and arel including the quadrature encoder-decoder, making the use case for a hobby grade robotic system a little marginal.
About the BeaglePilot: You can read here https://github.com/BeaglePilot/beaglepilot
BeaglePilot project aims to create the first Linux-based autopilot for flying robots using the BeagleBone and this project is now inactive.
The only other working product using the BeagleBone is @mirkix excellent implementation on a DIY cape called the BBBMINI
http://ardupilot.org/dev/docs/supported-autopilot-controller-boards.html#bbbmini-cape
I know this is an old post - but I recently started my project to build a 220mm drone during Beaglebone Blue. Since the BBBlue already has the cape integrated - I am still trying to figure out how to get ArduPilot on the system. The only resource I found after hours of searching was iamfatant’s guide.
Hello
Conversation & support is still active here
