while uploading firmeware DLL library are causing problems.
the cause of this would most likely be a failed update.
please run the update process again, or reinstall from MSI
Yes I’m having the same issue. I’ve uninstalled mission planner multiple times and reinstalled from MSI with no change.
Capture
what board are you uploading to?
