I have my 4 ESCs connected to the normal “main” outputs 1-4. I know I have to change the protocol to Dshot to do BLHeli passthrough but do I have to disconnect the connectors from “main” and plug them into “aux” on my Pixhawk?
Thanks
If you want to run Dshot on a Pixhawk you do. Then re-assign the Servo outputs.
Ah bugger. Okay, good to know. Was hoping passthrough could work on “main”.
I know you need “aux” for Dshot.
Actually, I don’t want to run Dshot.
I just want to program the settings of the ESCs.
And the reason I am asking this question is because it is difficult for me to access the servo connectors so I can’t easily try it.
Try it. Set SERVO_BLH_AUTO to 1 and see if it will connect via BLHeli suite.ESC’s must be powered.
see this topic for further information: blheli-32-passthrough-not-working
Thanks, this is now solved in a related separate thread I made as linked above by Arne-W.
I was following this:
https://ardupilot.org/copter/docs/common-dshot.html
which implies that setting SERVO_BLH_AUTO is only needed for Arduplane but I found I needed it for my quadcopter.
That is in reference to Planes that have a mix of Motors running Dshot and servos requiring PWM. All you need is 2 parameters set if you want Dshot on the Pixhawk Aux outputs. MOT_PWM_TYPE and SERVO_BLH_AUTO (assuming you want to use passthru). All other parameters at default. Check it out. If the Banner massage says Dshot 9-12 you are good.
Hi there, unfortunately those 2 settings didn’t work for me in that I was checking the message log in MP and it always said the outputs 1-12 were PWM. I discuss this over here:
where I mention those 2 params that didn’t get things working.
It’s a Pixhawk 1.
You were also saying you were on the main outputs but unless you are mixing protocol/timing groups you shouldn’t have to use the mask. If it’s working OK, I was just suggesting that it’s probably redundant.
I had 1 ESC on pin 9 (AUX1) and the other 3 ESCs on pins 2-4 (MAIN2-4).
It was just to see whether I should be on MAIN or AUX.
Got it. When MOT_PWM_TYPE is set to a Dshot protocol all outputs are set to Dhsot, except for the ones on the IOMCU, unless otherwise configured. For FC’s w/o an IOMCU that would be All outputs. So with a Dshot protocol set on a Pixhawk, and with no other parameter changes you should see PWM1-8 Dshotxxx9-12.
I see where the discrepancy is. If you set MOT_PWM_TYPE to a Dshot protocol but don’t assign any motors to the Aux outputs then all outputs Main and Aux will be set to PWM. If you assign 1 or more Aux outputs then all Aux outputs will be configured for Dshot.
Just to conclude this thread, the answer is yes, on the Pixhawk you must attach all ESC servo connections to the AUX ports.
