When migrating from 4.3.7 to 4.4.3, it does not take photos, and I am unable to configure it
I am using Cube Orange with a Sony Alpha 6000 camera and a servo-operated trigger. It works well (as always) on firmware 4.3.7. However, when I update to 4.4.3, I have not been able to make it work. I have tried with CAM1, CAM2, and both at the same time, but nothing happens; I can’t trigger the camera. When I revert to 4.3.7, everything works again. Any suggestions? Is there a parameter I might be forgetting?
Thank you!
What flight controller do you have? EDIT: sorry, I see Cube Orange! just say what servo output you are using.
Can you supply your parameter .param file, and say what server channel the camera trigger is on, and what RC Channel is (optionally) used to trigger it.
We would be looking for something like SERV09_FUNCTION,-1 where the camera trigger is connected.
And we need to figure out the value for RELAY_PIN depending on your FC.
Here’s the list for SERVO9 and up:
  • PWM1 50
  • PWM2 51
  • PWM3 52
  • PWM4 53
  • PWM5 54
  • PWM6 55
So you would set RELAY_PIN,50 when using SERVO9
this is my setup:
all relay is disable in -1
and this is my param file:
fw_4.4.3 dont trigger camera.param (17.9 KB)
Do you find something that I miss?
Thanks !
OK,
its working now.
some minor changes in setup. looks irrelevant but maybe help some one else:
all relay -1 (because im working on servo)
Cheers!
