Hi,all
I want to use LidarLite v3 for rangefinder through pwm, when I ready to set the parameters, I find two similar parameters, RNGFND_TYPE and RNGFND2_TYPE, what’s the differences between them, which one should I use?
Thanks a lot
Tom
Hi,all
Thanks a lot
Tom
Hi Tom,
RNGFND2 is for a second rangefinder. Those two parameters are exactly the same, but the first is for the first connected rangefinder and the second for a second rangefinder you might have connected.
Hi,OXINARF
Thanks for you response.
if I just connect one rangefinder on pixhawk, for example, LidarLite v3, pwm interface connect to pixhawk, which parameter should I use, RNGFND or RNGFND2
Tom
You should use RNGFND.
hi, i need info for set the maxbotix mb 1202 on i2c and how i can make It work coz until now all parameters are 0
