What will happen to VTOL if airspeed sensor fail? and its solution
Hello.
I wonder what will happen when VTOL airspeed sensor fail.
because I will operate expensive VTOL in BVLOS(beyond visual line of sight) flight.
I bought VTOL that can fly over 3 hours. it will fly over 50km in sea.
so I’m worrying about airspeed sensor’s clogging in BVLOS flight. I want to make a plan to deal with this problem.
I heard that airspeed sensor fails frequently, as it can be blocked.
https://ardupilot.org/plane/docs/fixed-wing-faq.html
I read through this webpages.
this page says when airspeed sensor failed and airspeed is too high, plane will lose altitude very fast and speed will try to gain. but there is no solution of this. will changing mode to FBWA help to solve this problem?
do FBWA mode use airspeed sensor…? controlling plane with joystick in FBWA mode will help dealing with this problem?
and above page says when airspeed sensor failed and airspeed is too high, plane will slow down and crash. but how about VTOL? it doesn’t say about that.
will Q_ASSIST activated when the speed is too slow?
how things will be going to when I turn of Q_ASSIST by set Q_ASSIST_SPEED to 0? will it crash?
and I wonder about the solution of this failure.
The solution is RCx_OPTION 106 (Disable Airspeed Use) .
Rolf
This is not a simple topic, because there are several options on what to do if an airspeed sensor fails. You can have the autopilot revert to synthetic airspeed and even let it go back to measured airspeed if it recovers. There are settings for maximum allowed discrepancy between GPS ground speed and measured airspeed as well.
I have a VTOL with airspeed sensor and I noticed that transitions to forward flight are much better with airspeed sensor as the transition speed is detected better. When in fixed wing mode, you have to manage and treat the airspeed sensor just the same way as with any fixed wing airplane with the considerations on the previous paragraph. I haven’t seen much use of the airspeed sensor during VTOL hover modes. It may be used for weathervaning, to help it hold in place in a windy day. Either way, with an expensive VTOL airplane, you need to do some field testing before sending it 50km over open sea
@Truth_T It’s a good idea to use two airspeeds. In my experience, when one airspeed fails, the EKF will use the other. If you only have one airspeed, the EKF will also jettison the airspeed after detecting an airspeed failure; but it could still crash.
Thanks. but my VTOL only have one air speed sensor even though they are expensive.
I asked the maker company but they said they were okay with one airspeed sensor.
anyway, I already bought additional airspeed sensor a week ago. I will try to install it after they arrive.
I’m always using cuav GPS and FC very well. Thank you.
Thank very much. does above paragraph mean “RCx_OPTION 106 (Disable Airspeed Use) .”?
I will use airspeed sensor always, but I just wondered emergency countermeasure when airspeed sensor fails. I have airspeed sensor installed already.
Great answers. thank you.
That was neither cynical nor ironic. If dangerous flight control results from the faulty measurement and Arduplane does not detect the faulty airspeed sensor itself, this is the only way to save the plane. Except switching to manual mode, which one BVLOS rather not routinely mastered via FPV. FBWA can work, but it does not have to work if the speed is measured much too low with a partially blocked pitot tube and the control surfaces therefore have much too wide deflections and shake the aircraft. I speak from my own experience from almost seven years of flying with airspeed sensors.
Rolf
It’s more about setting the correct ARAOD_OPTIONS
https://ardupilot.org/plane/docs/parameters.html#arspd-options
I’d spend some time getting very familiar with this page:
https://ardupilot.org/plane/docs/airspeed.html
This is familar topic to me.
We fly VTOL planes in 1+ hour BVLOS mapping missions and failing airspeed sensor is very common thing to happen if the plane encounters freezing conditions (blocked by snow or ice buildup).
This is how we are dealing with the possibility of airspeed failure:
Plane is 7,5 kg quadrotor VTOL, stall speed about 10m/s. Target airspeed during mission is 20m/s. Maximum real wind speed for our mapping missions is 8m/s.
ARSPD_FBW_MIN: 14
ARSPD_FBW_MAX: 32
AHRS_WIND_MAX: 12
ARSPD_WIND_MAX: 12
ARSPD_WIND_WARN: 11
ARSPD_OPTIONS: SpeedMismatchDisable, AllowSpeedMismatchRecovery
MIN_GNDSPD_CM: 1600
This should give autopilot some headroom to maintain at least safe-ish airspeed. But as usual, your mileage may vary. For us this has completely cured crashes caused by unrecoverable stalls during tight turns with bad airspeed data. Q assist cant really save tip stall condition. MIN_GNDSPD prevents plane from stalling before ASPD_OPTIONS can do its magic and disable the sensor because of speed mismatch. Typical blockage causes airspeed readings to go up to 30+m/s while ground speed tries to dip to single digits.
In Icing conditions you shouldn’t fly without a heated Pitot tube in the first place.
True.
But in real world it doesnt make much difference or could even be worse than not having heated pitot tube. Why? Because in our climate freezing conditions come and go more or less randomly. We prefer not to fly at all if there is such weather but things can change fast. Loosing airspeed is “great” early warning to RTL before plane is too iced up it does not want to fly anymore.
If you regularly operate in possible icing conditions you should have icing detector not rely on airspeed failure as icing indication.
I would love to have one but so far those have been too big or too heavy for such a small plane.
