Flying 3.4 today, i was in a loiter circle and from the sound of my motor, it seemed like my throttle had an effect on the motor.
I haven’t flown 3.4 a lot, but on 3.3 on a different plane, the throttle does nothing.
I did have stick mixing set to 2, then changed it back to 0.
so, does throttle do anything in a loiter?
thank you
RC_Mike
(RC Mike)
2
“As with Return To Launch (RTL) and AUTO mode you can “nudge” the plane while in LOITER using stick mixing, if enabled.”
Center stick will hold speed. High throttle will make it fly a little faster.
plane.ardupilot.com/wiki/loiter-mode/
ahh, didn’t see the throttle part anywhere.
thank you
