Hello.
I want to know the diffrence of Disable/No change in this failsafe options.
I read the description but couldn’t find description about Disable function.
will it follow last command of transmitter?
Hello.
It is about VTOL(ArduPlane)
It is written on this page.
FS_SHORT_ACTN = 3 disables taking action in ANY mode
So the ‘no change’ option disables an action if the plane is in LOITER
, AUTO
, THERMAL
, AVOID_ADSB
or GUIDED
mode, otherwise the plane will switch to CIRCLE
If it will follow your last command is probably up to your transmitter/receiver settings. Most receivers allow to define a failsafe action, i.e. set channel to specified value / keep last known value / ‘no pulses’.
