there are different connection options in Mission Planner TCP, UDP and UDPCI. I understand how TCP and UDP work, but I do not understand what the difference between UDP and UDPCI is, apart from the fact that I can specify an IP-address for the latter. Can someone point out the difference?
Thank you @Michael_Oborne for your answer. Does that mean that the UDP-link is somehow unidirectional?
I tried to connect over WIFI to the Pixracer using UDPCI. I specified the right IP-address but the connection did not work. What is the exact role of the IP-address?
