sjdroner
(sanjay)
May 21, 2021, 6:55am
#1
I have designed a quadcopter. Maximum it should have 2Kg MTOW. The 10-inch propeller can be availed.
Total weight so far (excluding motor) reaches approximately, 1.6Kg.
Under such configuration, what is the best suitable motor that can work with a 4S battery? I need a decent flight time so selecting 4S, probably 5000mAh.
Not mandatory, but it will be better if a product suggested is as per its availability in India.
dkemxr
(Dave)
May 21, 2021, 1:05pm
#2
2kg is getting heavy for a 10" propped craft. You will need a ~1000kV motors for that weight and prop.
sjdroner
(sanjay)
May 21, 2021, 1:22pm
#3
because I have calculated gimbal and camera weight too.
Yes. I am also looking for something around 900kv motor.
But I see, at 50%, thrust is quite less.
Do you think, T-motor Air gear 880 KV - https://store-en.tmotor.com/goods.php?id=726 will be good?
I am confused as it produces 430 gms thrust at 50% with 1045, 4S.
dkemxr
(Dave)
May 21, 2021, 1:35pm
#4
If your MTOW was ~ 1700g those might be a good choice.
sjdroner
(sanjay)
May 21, 2021, 1:37pm
#5
I don’t see any other good option.
What should be the ideal thrust at 50% for 2Kg.?
I found tarot 4006 620KV, which gives thrust more than 500 grams at 50%. However, the propeller size required is 1355.
dkemxr
(Dave)
May 21, 2021, 1:46pm
#6
500g or more.
Sunnysky makes a 2212-980kV.
A 620kV motor on 6S may work.
sjdroner
(sanjay)
May 21, 2021, 1:58pm
#7
Yeah, so that 500 is fine as per the same calculation.
I like that Sunny sky 2212-980 kv. not available in India
Tarot 620kv with 6S, you mean with 10 inch propeller?
dkemxr
(Dave)
May 21, 2021, 2:20pm
#8
Yes, but not sure that actual motor will handle 6S. I was just suggesting a lower kV motor on 6S with 10" props as an option.
