I’m quite new with the quadplane and I’m trying to understand what does this parameter do.
I’ve already read the description here: http://ardupilot.org/plane/docs/parameters.html#q-wp-radius-waypoint-radius but it doesn’t matter what value it takes, quadplane’s behaviour does not change.
Could someone explain it to me please? Maybe it’s a bug?
I never tested it, but from the description I was lead to understand that if you are in VTOL mode (so not transistion to fixed wing) and doing mission this way, then (unlike fixed wing) VTOL can nail a WP precicly and start going in another direction at an angle (instead of a curve like in fixed wing mode). This is carried over from Copter I belive. So incase you want to do VTOL mode waypoint but dont want to plane to be wasting time and energy getting all the way to the 1x1m of the waypoint, but rather consider it is done after it get X (the value you set here) m fromt that waypoint.
Does this make sense?
Absolutely. I was expecting this behaviour too, but it doesn’t work like that. Regardless of the mode, the quadplane ignores Q_WP_RADIUS
Here’s an example, in VTOL mode, with WP_RADIUS = 60 (m) and Q_WP_RADIUS = 100 (cm):
Executing nav command ID #85
Reached waypoint #8 dist 14m
Executing nav command ID #16
Reached waypoint #7 dist 6m
Reached waypoint #6 dist 6m
Reached waypoint #5 dist 6m
Reached waypoint #4 dist 9m
Reached waypoint #3 dist 11m
Reached waypoint #2 dist 15m
EKF yaw reset -4.13
Reset alt target to -0.1
Executing nav command ID #84
Any progress on this issue? I tried to run a few simple VTOL missions in SITL + Mavproxy, and am also experiencing problems similar to what @Echo has encountered. I am using Plane 3.8.4 firmware, and flew at SITL’s default location (CMAC).
Despite changing the value of Q_WP_RADIUS (from the default 200cm to 1000cm, and even to extremities like 9000cm!), the aircraft simply ignores the value of Q_WP_RADIUS.
For example, in the screenshot below, the console shows that the aircraft reaches the waypoint once it reaches ~20 of the waypoint, but this remains constant even when Q_WP_RADIUS is changed.
Finally, I notice that an issue has been opened on Github recently (https://github.com/ArduPilot/ardupilot/issues/8677), but has not received any response. Would appreciate if any developer could help to look into this!
