I am running the Auto Analysis of my DataFlash logs in Mission Planner. I keep failing the PM Test. The line reads something like “Test: PM = FAIL - 18 slow loop lines found, max 10.4% on line 20084”. Can someone tell me what the PM test is measuring?
copied from Ardupilot.com
PM (performance monitoring):
RenCnt: DCM renormalization count – a high number may indicate problems in DCM (extremely rare);
RenBlw:DCM renormalization blow-up count – how many times DCM had to completely rebuild the DCM matrix since the last PM. Normally innocuous but a number that constantly grows may be an indication that DCM is having troubles calculating the attitude (extremely rare);
FixCnt: the number of GPS fixes received since the last PM message was received (it’s hard to imagine how this would be useful);
NLon: number of long running main loops (i.e. loops that take more than 5% longer than the 10ms they should);
NLoop: the total number of loops since the last PM message was displayed. Normally 1000 and allows you to calculate the percentage of slow running loops which should never be higher than 15%;
MaxT: the maximum time that any loop took since the last PM message. This should be close to 10,000 but will be up to 6,000,000 during the interval where the motors are armed;
PMT: a number that increments each time a heart beat is received from the ground station; and
I2CErr: the number of I2C errors since the last PM message. Any I2C errors may indicate a problem on the I2C bus which may in turn slow down the main loop and cause performance problems.
OK, thank you. So I guess I am getting an NLon or NLoop error? Is there a way to fix this? Does it indicate a problem with the Pixhawk or something else?
