it will work however just it will have a slight delay in the handling of the aircraft. e.g going forward, left right will not be as responsive as slow spinning rotors.
I don’t have experience of how it feels like, but it will probably be ok, since this will mainly be used for steady video recording, and smooth movements, so i will definitely try 6s (low C high capasity) and 15x5, if its not so good, and can change to 5s.
I have a Tarot 650 with 16x5.5 carbon props and 4108-480KV motors. My AUW is 1.8kg with one 4S 5000mah battery, 2.5kg with 2x5000mah in parallel. I normally only run one battery and holy crap does it make thrust. Throttle mid is somewhere around 380 and full throttle climbs like nobody’s business, though I haven’t measured the climb rate.
I haven’t had much experience flying it yet, but it does seem to be pretty good and flight times are decent, but again, I haven’t had a chance to time the battery life. I recently got loiter/althold to work and they seem to work very well so soon ill time it. I too plan on using it for video/imaging.
