What does "mag calb log" do?
Does anybody know what the function “mag calb log” on the “temp” window does? I used in on two similar logs and get quite different values. Is this function any good?
It reads the Mag offsets from a chosen log and either simply displays them or if you are connected to a Flight Controller over rights the existing offsets with the ones from the log you chose. I can’t think of too many circumstances why you would want to do this and many where it’s not good.
I would say you better re-do the mag calibration that you over wrote with this function.
Button
Thanks, I already figured I’ll better calibrate again.:sweat_smile:
Would be cool to have a button to get MOTBATs from a log.
You can just copy them from the parameter file the same as the mag offsets.
