What could be the problem when high speed yaw cause spiral
What would be a likely cause when i fly with acro mode. Doing a high speed forward and then do a high speed yaw turn it just turn uncontrollably and loss of power and crash?
I thought its compass issue, fixed it doesn’t work.
Remove compass, still the same?
Maybe wire too thin? Replace thicker wires. Still the same?
Autotune my yaw, still the same.
Why could this happen?
Acro doesn’t need compass.
Check the logs for motor saturating at the max PWM value. (RCOU.Cx message in the logs)
Demanding very high yaw rate during high-speed cruise may make the motors run at full throttle leading to loss of the motors ability to stabilize the roll and pitch axis.
Solution:
Try limiting the maximum demanded yaw rate: ACRO_Y_RATE
Also considering tweaking other ACRO_Y_x params.
Problem is when I do auto mode it also had the same problem when flying a distance and yaw it will spiral out of control.
I suspect the battery discharge rate is too low causing esc to lock up due to not enough power to motor? Maybe I should try what you mentioned.
Maybe I had mess up my yaw during autotuning. Maybe you are right. Will test more tomorrow.
Post the .bin log file otherwise everything here is just a guess.
Please help me have a look. Been trying to figure what’s wrong. Can’t figure.https://1drv.ms/u/s!AjRAfK6FePu2nWaGPo_HM733vdmA?e=6XvcQF
Yup, you hit motor saturation a few times. So you might be hitting limits for what the quad can do, but I don’t think that was the cause of the crash.
I think motor/esc 3 failed or some how stopped producing enough power. The current doesn’t match what it should as motor 3 goes to full, compared to when the other motors do the same.
Check the wiring to #3, the ESC, the motor itself, the prop nut. The crash wasn’t the result of a tune issue, it was likely a hardware failure or limitation.
Thanks bro… You are really good.
Hi Allister,
I did some more test, what you said the other time is correct one of the wire seems to be off, which I soldered. but still face similar problem with the spiraling when pushing my joysticks… I am trying to learn to read these logs.
I interference and the placement of my FC in a stack is a cause of these.
First image is done with a GNSS/Compass.
Second Image I removed the compass. but the imu seems to react badly.
Could this be true that the cause of the spiraling also comes from intereferance?
type or paste code here
https://1drv.ms/u/s!AjRAfK6FePu2nW1Qs7OntgEj0UyW?e=kJf6pu
The compass is a mess.
I just ran the log through magfit at got these:
COMPASS_OFS_X,-124.188354
COMPASS_OFS_Y,25.244705
COMPASS_OFS_Z,75.7619
COMPASS_DIA_X,0.98534054
COMPASS_DIA_Y,1.0124199
COMPASS_DIA_Z,1.0022396
COMPASS_ODI_X,0.009800853
COMPASS_ODI_Y,-0.09328445
COMPASS_ODI_Z,0.04553168
COMPASS_MOT_X,0.41105524
COMPASS_MOT_Y,3.210266
COMPASS_MOT_Z,-2.6324465
COMPASS_SCALE,1.0253417
COMPASS_ORIENT,6
COMPASS_MOTCT,2
Give that a try and see how it does. Don’t remove the compass unless you re-configure for that, and that involves some other hardware so it’s not a quick solution.
Thanks its all working well now.
