What am I doing wrong with the FFT analysis?
I have reconfigured my scale Agusta109 (800 blades, 10kg, four blade) ( now less weight, less rpm).
After the first flight I wanted to do the Measuring Vibration with IMU Batch Sampler¶ as described in the wiki.
For this I had done the preparations as described in the wiki.
After the flight, I wanted to use the log in the FFTUI
to look at it. However, the displayed graph shows negative amplitude values.
FFT_Analyse1
Here ist he Bin-File:
What am I doing wrong?
Thank you for your help.
BR
Heri
It is very very normal to have negative numbers.
Nothing other than using a Log scale. If you want it to look like this then check the magnitude box before loading the log file:
@dkemxr
@amilcarlucas
Thank you for your advice.
Life is so simple when you know what you have to do. :kissing_heart:
BR
Heri
