I see throttle on the RC Calibration, but nothing on servo output, I never had this issue with previous setups. I am using blheli_s, it’s armed and see the changes of throttle, here is the log and some screenshots:
RCOut: PWM:1-6 DS150:7-10 PWM:11-13
Throttle armed
PWM1~PWM13 are Dshot and PWM capable. (based on matek h743-wing v3, and divided motor + servo in different groups as needed)
I would set SERVO_BLH_AUTO back to 0. This parameter is only for multirotors I think. And _BLH_DEBUG back to 0.
Then you can also test SERVO_BLH_MASK = 960 (set the hole timer group ch7,8,9,10)
On my configurations on h743 controllers I have ch1, ch2 set to BLHeli32 ESCs DShot150 (timer group1) and all other outputs as PWM with SERVO_BLH_MASK 3 and OTYPE 4 and it works
I have connected my throttle motor on main out 3 so I have selected servo ch3 as RCIN3,
If you have connected your throttle motor to MAIN OUT 1 than servo ch3 = RCIN1
Could you please explain where do you change this? if it’s RCMAP then I have it correctly setup, my Throttle is on RC1 and S7, S8 has throttle option enabled (which is 70)
