I am using 3.2 firmware on my quadcopter F450 with 2.8apm FC
I am making 6 waypoint with auto take off, using Do jump command with -1
Means unlimited loop,
All flight is ok but went it hit minute 2-8 each waypoint the quad will going down abit each lap
at the end about 3 meter from ground i switch to RTL it going up like normal then switch again to auto the quad will continue the waypoint but in 3 meter from ground.
I have try continue the fligh but with 2 lap it will touch the ground
What the problem ?
