I try to write a lua script to solve the automatic and manual dump with a boat. The manual mode works perfectly, the problem with my automatice mode. I dont know exatly how to get my boat target location and the boat location. I try work from Here
I hope you can help me
Thanks a lots
My code:
local uritbezar = true
local work_flag = false
local mode = 0 -- 0 - ürítés 1 - automata
local wp_radius = 2
local is_target_reached_flag = false
function work_function()
if uritbezar then
SRV_Channels:set_output_pwm_chan_timeout(4, 1915, 1000)
gcs:send_text(6, "urit---")
SRV_Channels:set_output_pwm_chan_timeout(5, 927, 1000)
else
SRV_Channels:set_output_pwm_chan_timeout(4, 970, 1000)
gcs:send_text(6, "---bezar")
SRV_Channels:set_output_pwm_chan_timeout(5, 1857, 1000)
work_flag = false
end
uritbezar = not uritbezar
end
function ch_checker()
local ch7 = rc:get_pwm(7)
gcs:send_text(6, "Chanel check")
if ch7 == 1514 then
mode_code = 0
return mode_code, true
elseif ch7 == 2003 then
mode_code = 1
if is_target_reached_flag then
work_flag = true
end
return mode_code, is_target_reached_flag
elseif ch7 == 1024 then
mode_code = 0
work_flag = true
return mode_code, false
end
end
function is_target_reached()
local error_c = false
gcs:send_text(0, "cel_vizsgalat")
local target = vehicle:get_target_location()
local curr_loc = ahrs:get_position()
if not target then
gcs:send_text(0, "Target hiba")
error_c = true
end
if not curr_loc then
gcs:send_text(0, "Location hiba")
error_c = true
end
if error_c then
return
end
gcs:send_text(6, string.format("Target: %d %d", target:lat(), target:lng()))
gcs:send_text(6, string.format("Location: %d %d", curr_loc:lat(), curr_loc:lng()))
local target_dist = curr_loc:get_distance(target)
gcs:send_text(6, string.format("Distance: %d", target_dist))
if (target_dist < wp_radius) then
gcs:send_text(0, "cel_elerve")
is_target_reached_flag = true
else
end
return
end
function update()
mode, state = ch_checker()
gcs:send_text(6, string.format("ModCode: %d", mode))
if state and work_flag then
work_function()
return update, 7000
end
if mode == 1 then
gcs:send_text(0, "Automata mode")
is_target_reached()
elseif mode == 0 then
gcs:send_text(0, "Manual mode")
end
return update, 1000
end
gcs:send_text(6, "a_scripttel_vezerelt_urites_mukodik")
return update, 5000
