RNGFND1_MAX_CM = “600” (i.e. 6.0m max range for v3.0 ver)
RNGFND1_MIN_CM = “20” (i.e. 20cm min range for v3.0 ver)
RNGFND1_STOP_PIN = 55 (Enter GPIO number for pin attached to JSN-SR04T “Trigger” pin. See GPIOs.) (Aux6 = GPIO pin 55)
RNGFND1_PIN = 54 (Enter GPIO number for pin attached to JSN-SR04T “Echo” pin.) (Aux5 = GPIO pin 54)
RNGFND1_TYPE = “30” (HC-SR04 sonar)
RNGFND1_ORIENT = “25” (Downward facing) if used for altitude control.
Yes, It connects the same as other cheap Ultrasonic sensors to 2 GPIO configured ports. Aux ports can be configured for GPIO. But there will not be 5V on those ports.
SERVO13_FUNCTION “-1” (to enable GPIO on AUX 5)
SERVO14_FUNCTION “-1” (to enable GPIO on AUX 6)
