How can these warnings be resolved? What caused the warning?
Yaw alignment isn’t an issue. That’s a good thing. It will come up on every flight.
Terrain clamping … I"m not sure.
GPS, see my other post. (don’t double post problems, that just confuses the issue)
Thank you very much for your answer. The third question I would like to ask is Yaw Imbslance in the message bar below
I’m not sure about the Yaw imbalance. I believe that is a helicopter specific issue so I’ll have to let one of the heli folks address that.
good Thank you very much for your reply
@wangjiayun
“Yaw imbalance”
i have the same problem with one of my helicopters. In an older post I think I read that the toe-in of the tail rotor blades are not preset accurately enough. Therefore, the back torque of the tail rotor is still not correct at the moment the helicopter takes off.
If I remember correctly, this can be seen by the fact that the PIDY-I value is too high. I’m sure Chris @ChrisOlson or Bill @bnsgeyer can tell you something about this.
With my helicopter I recognize that it turns the nose away briefly at the moment of takeoff, until the FC has caught it again. I therefore adjust the angle of attack of the tail rotor blades from flight to flight until I see an improvement.
BR
Heri
Hi @wangjiayun
@heri is correct. That is what this warning refers to. Typically I set my tail rotor pitch so that the SERVO4_TRIM corresponds to the tail rotor pitch required for hover. By the way, There is a new feature in 4.4 that replaces the existing collective to yaw with one that better predicts the required tail rotor pitch for collective position.
Good news. Will make fine tuning easier.
@heri it talks about this in this new wiki page on tail rotor setup. The bottom of the page describes the collective to tail rotor compensation.
https://ardupilot.org/copter/docs/traditional-helicopter-tailrotor-setup.html
