I want to know the method of how to change /add something(XYZ) in mission planner frontend.
Kindly suggest me the correct code that I should run.
Thank you.
Thank you.
Mission planner is open source and can be found in here GitHub - ArduPilot/MissionPlanner: Mission Planner Ground Control Station (c# .net)
