I am trying to compile ArduSub on Linux Ubuntu 16.04. I have followed all necessary steps from
https://www.ardusub.com/developers/developers.html
This is my output, with cmake related error at the end:
prince@Prince-ThinkPad-W530:~/ardupilot$ ./waf clean 'clean' finished successfully (0.484s) prince@Prince-ThinkPad-W530:~/ardupilot$ ./waf configure --board px4-v2 Setting top to : /home/prince/ardupilot Setting out to : /home/prince/ardupilot/build Autoconfiguration : enabled Setting board to : px4-v2 Checking for program 'arm-none-eabi-ar' : /usr/bin/arm-none-eabi-ar Using toolchain : arm-none-eabi Checking for 'g++' (C++ compiler) : /usr/bin/arm-none-eabi-g++ Checking for 'gcc' (C compiler) : /usr/bin/arm-none-eabi-gcc Checking for HAVE_CMATH_ISFINITE : no Checking for HAVE_CMATH_ISINF : no Checking for HAVE_CMATH_ISNAN : no Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : no Checking for NEED_CMATH_ISINF_STD_NAMESPACE : no Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : no Checking for header endian.h : not found Checking for header byteswap.h : not found Checking for program 'cmake' : /usr/bin/cmake Checking cmake version : 3.5.1 Checking for program 'ninja, ninja-build' : not found Checking for program 'make' : /usr/bin/make Checking for program 'python' : /usr/bin/python Checking for python version >= 2.7.0 : 2.7.12 Checking for program 'python' : /usr/bin/python Checking for python version >= 2.7.0 : 2.7.12 Source is git repository : yes Update submodules : yes Checking for program 'git' : /usr/bin/git Gtest : PX4 boards currently don't support compiling gtest Checking for program 'arm-none-eabi-size' : /usr/bin/arm-none-eabi-size Benchmarks : disabled Unit tests : disabled 'configure' finished successfully (0.653s) prince@Prince-ThinkPad-W530:~/ardupilot$ ./waf build sub Waf: Entering directory `/home/prince/ardupilot/build/px4-v2' [ 5/14] Processing modules/mavlink/message_definitions/v1.0/ardupilotmega.xml [ 6/14] Processing uavcangen: modules/uavcan/dsdl/uavcan/CoarseOrientation.uavcan modules/uavcan/dsdl/uavcan/Timestamp.uavcan modules/uavcan/dsdl/uavcan/equipment/actuator/1010.ArrayCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/actuator/1011.Status.uavcan modules/uavcan/dsdl/uavcan/equipment/actuator/Command.uavcan modules/uavcan/dsdl/uavcan/equipment/ahrs/1000.Solution.uavcan modules/uavcan/dsdl/uavcan/equipment/ahrs/1001.MagneticFieldStrength.uavcan modules/uavcan/dsdl/uavcan/equipment/air_data/1020.TrueAirspeed.uavcan modules/uavcan/dsdl/uavcan/equipment/air_data/1021.IndicatedAirspeed.uavcan modules/uavcan/dsdl/uavcan/equipment/air_data/1025.AngleOfAttack.uavcan modules/uavcan/dsdl/uavcan/equipment/air_data/1026.Sideslip.uavcan modules/uavcan/dsdl/uavcan/equipment/air_data/1028.StaticPressure.uavcan modules/uavcan/dsdl/uavcan/equipment/air_data/1029.StaticTemperature.uavcan modules/uavcan/dsdl/uavcan/equipment/camera_gimbal/1040.AngularCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/camera_gimbal/1041.GEOPOICommand.uavcan modules/uavcan/dsdl/uavcan/equipment/camera_gimbal/1044.Status.uavcan modules/uavcan/dsdl/uavcan/equipment/camera_gimbal/Mode.uavcan modules/uavcan/dsdl/uavcan/equipment/esc/1030.RawCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/esc/1031.RPMCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/esc/1034.Status.uavcan modules/uavcan/dsdl/uavcan/equipment/gnss/1060.Fix.uavcan modules/uavcan/dsdl/uavcan/equipment/gnss/1061.Auxiliary.uavcan modules/uavcan/dsdl/uavcan/equipment/gnss/1062.RTCMStream.uavcan modules/uavcan/dsdl/uavcan/equipment/hardpoint/1070.Command.uavcan modules/uavcan/dsdl/uavcan/equipment/hardpoint/1071.Status.uavcan modules/uavcan/dsdl/uavcan/equipment/indication/1080.BeepCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/indication/1081.LightsCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/indication/RGB565.uavcan modules/uavcan/dsdl/uavcan/equipment/indication/SingleLightCommand.uavcan modules/uavcan/dsdl/uavcan/equipment/power/1090.PrimaryPowerSupplyStatus.uavcan modules/uavcan/dsdl/uavcan/equipment/power/1091.CircuitStatus.uavcan modules/uavcan/dsdl/uavcan/equipment/power/1092.BatteryInfo.uavcan modules/uavcan/dsdl/uavcan/equipment/range_sensor/1050.Measurement.uavcan modules/uavcan/dsdl/uavcan/equipment/safety/1100.ArmingStatus.uavcan modules/uavcan/dsdl/uavcan/protocol/1.GetNodeInfo.uavcan modules/uavcan/dsdl/uavcan/protocol/2.GetDataTypeInfo.uavcan modules/uavcan/dsdl/uavcan/protocol/341.NodeStatus.uavcan modules/uavcan/dsdl/uavcan/protocol/4.GetTransportStats.uavcan modules/uavcan/dsdl/uavcan/protocol/4.GlobalTimeSync.uavcan modules/uavcan/dsdl/uavcan/protocol/5.Panic.uavcan modules/uavcan/dsdl/uavcan/protocol/5.RestartNode.uavcan modules/uavcan/dsdl/uavcan/protocol/6.AccessCommandShell.uavcan modules/uavcan/dsdl/uavcan/protocol/CANIfaceStats.uavcan modules/uavcan/dsdl/uavcan/protocol/DataTypeKind.uavcan modules/uavcan/dsdl/uavcan/protocol/HardwareVersion.uavcan modules/uavcan/dsdl/uavcan/protocol/SoftwareVersion.uavcan modules/uavcan/dsdl/uavcan/protocol/debug/16370.KeyValue.uavcan modules/uavcan/dsdl/uavcan/protocol/debug/16383.LogMessage.uavcan modules/uavcan/dsdl/uavcan/protocol/debug/LogLevel.uavcan modules/uavcan/dsdl/uavcan/protocol/dynamic_node_id/1.Allocation.uavcan modules/uavcan/dsdl/uavcan/protocol/dynamic_node_id/server/30.AppendEntries.uavcan modules/uavcan/dsdl/uavcan/protocol/dynamic_node_id/server/31.RequestVote.uavcan modules/uavcan/dsdl/uavcan/protocol/dynamic_node_id/server/390.Discovery.uavcan modules/uavcan/dsdl/uavcan/protocol/dynamic_node_id/server/Entry.uavcan modules/uavcan/dsdl/uavcan/protocol/enumeration/15.Begin.uavcan modules/uavcan/dsdl/uavcan/protocol/enumeration/380.Indication.uavcan modules/uavcan/dsdl/uavcan/protocol/file/40.BeginFirmwareUpdate.uavcan modules/uavcan/dsdl/uavcan/protocol/file/45.GetInfo.uavcan modules/uavcan/dsdl/uavcan/protocol/file/46.GetDirectoryEntryInfo.uavcan modules/uavcan/dsdl/uavcan/protocol/file/47.Delete.uavcan modules/uavcan/dsdl/uavcan/protocol/file/48.Read.uavcan modules/uavcan/dsdl/uavcan/protocol/file/49.Write.uavcan modules/uavcan/dsdl/uavcan/protocol/file/EntryType.uavcan modules/uavcan/dsdl/uavcan/protocol/file/Error.uavcan modules/uavcan/dsdl/uavcan/protocol/file/Path.uavcan modules/uavcan/dsdl/uavcan/protocol/param/10.ExecuteOpcode.uavcan modules/uavcan/dsdl/uavcan/protocol/param/11.GetSet.uavcan modules/uavcan/dsdl/uavcan/protocol/param/Empty.uavcan modules/uavcan/dsdl/uavcan/protocol/param/NumericValue.uavcan modules/uavcan/dsdl/uavcan/protocol/param/Value.uavcan [ 7/14] Creating build/px4-v2/ap_version.h [ 8/14] CMake Configure px4 [ 9/14] PX4: Copying rc.APM to px4-extra-files/ROMFS/init.d/rc.APM [10/14] PX4: Copying rc.error to px4-extra-files/ROMFS/init.d/rc.error [11/14] PX4: Copying rcS to px4-extra-files/ROMFS/init.d/rcS [12/14] PX4: Copying px4fmuv2_bl.bin to px4-extra-files/ROMFS/bootloader/fmu_bl.bin -- nuttx-px4fmu-v2-apm -- could not find gdb -- could not find gdbtui -- Configuring incomplete, errors occurred! CMake Error at cmake/toolchains/Toolchain-arm-none-eabi.cmake:62 (message): could not find genromfs Call Stack (most recent call first): /usr/share/cmake-3.5/Modules/CMakeDetermineSystem.cmake:98 (include) CMakeLists.txt:204 (project) CMake Error: CMAKE_ASM_COMPILER not set, after EnableLanguage [13/14] CMake Build px4 msg_gen make: *** No rule to make target 'msg_gen'. Stop. Running from the source directory Validation skipped for /home/prince/ardupilot/modules/mavlink/message_definitions/v1.0/ardupilotmega.xml. Parsing /home/prince/ardupilot/modules/mavlink/message_definitions/v1.0/ardupilotmega.xml Note: message DATA64 is longer than 64 bytes long (74 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message DATA96 is longer than 64 bytes long (106 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message REMOTE_LOG_DATA_BLOCK is longer than 64 bytes long (214 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message DEVICE_OP_READ_REPLY is longer than 64 bytes long (143 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message DEVICE_OP_WRITE is longer than 64 bytes long (187 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Validation skipped for /home/prince/ardupilot/modules/mavlink/message_definitions/v1.0/common.xml. Parsing /home/prince/ardupilot/modules/mavlink/message_definitions/v1.0/common.xml Note: message GPS_STATUS is longer than 64 bytes long (109 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message ATTITUDE_QUATERNION_COV is longer than 64 bytes long (80 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message GLOBAL_POSITION_INT_COV is longer than 64 bytes long (189 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message LOCAL_POSITION_NED_COV is longer than 64 bytes long (233 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message HIL_ACTUATOR_CONTROLS is longer than 64 bytes long (89 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message HIGHRES_IMU is longer than 64 bytes long (70 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message HIL_SENSOR is longer than 64 bytes long (72 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message SIM_STATE is longer than 64 bytes long (92 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message FILE_TRANSFER_PROTOCOL is longer than 64 bytes long (262 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message HIL_STATE_QUATERNION is longer than 64 bytes long (72 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message LOG_DATA is longer than 64 bytes long (105 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message GPS_INJECT_DATA is longer than 64 bytes long (121 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message SERIAL_CONTROL is longer than 64 bytes long (87 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message ENCAPSULATED_DATA is longer than 64 bytes long (263 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message RESOURCE_REQUEST is longer than 64 bytes long (251 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message FOLLOW_TARGET is longer than 64 bytes long (101 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message CONTROL_SYSTEM_STATE is longer than 64 bytes long (108 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message AUTOPILOT_VERSION is longer than 64 bytes long (68 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message GPS_INPUT is longer than 64 bytes long (71 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message GPS_RTCM_DATA is longer than 64 bytes long (190 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message V2_EXTENSION is longer than 64 bytes long (262 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message CAMERA_INFORMATION is longer than 64 bytes long (94 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message CAMERA_IMAGE_CAPTURED is longer than 64 bytes long (263 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message LOGGING_DATA is longer than 64 bytes long (263 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Note: message LOGGING_DATA_ACKED is longer than 64 bytes long (263 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit. Validation skipped for /home/prince/ardupilot/modules/mavlink/message_definitions/v1.0/uAvionix.xml. Parsing /home/prince/ardupilot/modules/mavlink/message_definitions/v1.0/uAvionix.xml Merged enum MAV_CMD Found 208 MAVLink message types in 3 XML files Generating C implementation in directory /home/prince/ardupilot/build/px4-v2/libraries/GCS_MAVLink/include/mavlink/v2.0/ardupilotmega Generating C implementation in directory /home/prince/ardupilot/build/px4-v2/libraries/GCS_MAVLink/include/mavlink/v2.0/common Generating C implementation in directory /home/prince/ardupilot/build/px4-v2/libraries/GCS_MAVLink/include/mavlink/v2.0/uAvionix Copying fixed headers for protocol 2.0 to /home/prince/ardupilot/build/px4-v2/libraries/GCS_MAVLink/include/mavlink/v2.0 WARNING: Unable to load XML validator libraries. XML validation will not be performed Waf: Leaving directory `/home/prince/ardupilot/build/px4-v2' Build failed -> task in 'px4_msg_gen' failed (exit status 2): {task 140702271472896: cmake_build_task -> } ['/usr/bin/cmake', '--build', '/home/prince/ardupilot/build/px4-v2/modules/PX4Firmware', '--target', 'msg_gen']
Thanks for the help in advance.
