hi,
can you explain what happened ?
thanks
You need to at least tell us what you’re looking for. All I see is a drone that didn’t arm because it’s in the wrong mode, has no radio, and the GPS doesn’t have a position.
And tlog files are very limited in their use. Post a .bin file from the drone.
Also give us some details on the drone relevant to the situation.
Set ARMING_CHECK, 1. If there are problems with that then you need to fix them before flying.
hi,
thanks for the answer and i apologie : i sent the wrong file and i’m out of the office for the week-end !
i will post the right one monday.
anyway, my configuration is : dophin VTOL 6s.
FC : speedy bee 405 wing
ESC : 4 in one holybro 55 amp
motors : 3x motors brother hobby 2806.5 1700kv
propellers : 6X4X3
battery : 1600 mah 6s.
today i crashed the plane :
the flight mode : qloiter
qholter
fbwb.
problem number 1 : i put PWR_MAX at 600 w , when i begin the transition, i get 1000 w , i arrive at 25 m/s of speed, the throttle goes to the minimum and after that goes back to the max … the motors are too poweful for the plane , is it possible to limit the power in transition ?
problem number 2 : after the transition , when the power come back , i saw the plane turn on its yaw axis … and notice that the left propeller had slipped on the motor axis. i think that i need to limit the power on this plane…why goes the power to the max after transition ?
here is the.bin
sorry one more time !
