Hi all,
I am interested in implementing a VTOL tandem wing platform with 8 propellers.
The platform that I have in mind closely follows the Airbus Vahana and the NASA LA-8 Aerodrome.
I was wondering whether this is something which can be implemented on the stock Plane 4.08 firmware. As far as I can tell the platforms have the following features -
- Tandem wings with control surfaces on both the fore and aft wings.
- For the LA-8 there is an additional V-tail.
3.The propeller directions for the LA-8 are shown below. In hover this is akin to an octocopter in a H configuration, where the H is rotated by 90 degrees and the motor directions are the same on either side of the aircraft.
- Variable pitch on some or all of the propellers for the Vahana. Though I suspect there is not enough motor channels in the firmware.
Appreciate any suggestions the you might have. Thank you.
