I am struggling with few parameter settings and need some help.
I need few tips on configuring my VTOL properly for my maiden flight and some fine tuning. My setup is;
Pixhawk 2.4.8
H Frame.
Mission planner.
I have set the Transmitter for 3 flight modes for initial first outdoor test.
a) Manual
b) QStabilize
c) FBWA
In QStabilize mode I can get the quad motors to work properly however I can not move aileron or elevator.
My assumption was that when I am in FBWA mode, I should be able to control the ailerons and elevator but its not happening and no forward throttle control.
The Pixhawk outputs are set and programmed as shown below.
You can monitor the ‘Servo Output’ value in Mission Planner.
If the bar moves when you operate the control sticks, it’s likely a hardware issue with the servo. If it doesn’t, the issue may be related to the parameter settings. This will help you identify the problem and find a solution more quickly.
Do you have a safety switch on your aircraft? That could also be the reason to the issue.
I recommend having someone review the parameter files you’ve uploaded for further assistance. There are many ArduPilot experts here who can also evaluate the overall status of your aircraft using the parameter file.
Apologies for interrupting your post—now I need to focus on resolving my MAVLink programming issue.
