Hello. I can’t understand my problem with my VTOL. The flight controller is installed pixhawk orange. I take off in manual mode as a quad. I gain altitude of 40 or 50 meters. I switch to cruise mode. The plane starts a normal flight, and then there is a sharp loss of altitude of 15-20 meters. Then the altitude is not lost. The plane gains the required altitude and flies according to the mission normally. I tried to take off in auto mode. The plane gained altitude according to the task of 40 meters as a quadcopter, then switched to airplane mode, after that the altitude loss is 20 meters. Then leveling and gaining altitude according to the task. This happens every time during takeoff. I can’t understand the problem. Please help. Thank you.
Please post a .bin log. It can be caused by a too aggressive transition settings leading to transition before minimum airspeed is reached.
Thanks for your reply. I will add my VTOL settings file now. Next I will add one of the flight BIN files.
Prochivka.param (22.3 KB)
Unfortunately my BIN files are too big, there is no way to upload them here. The smallest is 74mb, and here no more than 44 are allowed.
Use popular file sharing service like Google Drive, DropBox, Mega.nz…
At first glance, it seems like the CG might be incorrect, possibly shifted forward. But please upload the BIN file so we can take a closer look.
Sorry, I somehow didn’t think about it. Here is the BIN file of one of the flights. https://drive.google.com/file/d/1V_6HP2bj1pD2X8ih28Q4aNcJB28mwkQb/view?usp=sharing
The centering is correct. Before each takeoff I hang the plane. The problem confuses me. The plane takes off well as a copter. Then it switches to airplane mode. It flies well and smoothly and then abruptly lowers the nose and loses altitude. Having lost 15-20 meters it levels out and begins to gain altitude again according to the flight task.
your bin file only has QRTL and QSTABILIZE
I will fly on Monday. I will send a new flight file. I changed the parameter Q_TRANSITION_MS, made it 5000. I will check, maybe this will change something.
Hello. I have reprogrammed the autopilot. I have made a takeoff in automatic mode. No changes. The plane takes off as a quadcopter, then airplane mode, it flies normally, then suddenly loses altitude, then gains altitude again and flies according to the mission. I cannot understand the reason. I am attaching the bin file. I really hope for your help. https://drive.google.com/file/d/1vGRERDUKOZ6pCgE8iy__kHMdFacxQcq7/view?usp=sharing
you can see your elevator reach high value during your level flight. that mean CG or trim value of elevator for level flight.
Thank you very much for your reply! Do you think a more rearward center of gravity would make a difference? I will try to make the offset with a more rearward center of gravity and report the result. Thanks again.
Hello. I adjusted the elevator. Made the rear centering as far as possible. Made several flights. Nothing changed. In automatic mode, the plane in copter mode gains a specified altitude, goes into horizontal flight, then starts to dive with a loss of 15-20 meters in altitude. Then it levels out and flies normally all the time. This only happens after switching from copter mode to airplane. It seems to me that the software does this on purpose. I cannot understand the reason. I have two VTOLs. The second one does not have such problems. I changed the autopilot, changed the firmware. No changes. I cannot understand the reason.
Q ASSIST SPEED 16m/s → 20m/s
I think you should do tuning for fixed wing
I currently have Q ASSIST SPEED set to 16 m/s. 20m/s I don’t think it’s worth it anymore, because the copter’s engines will be constantly on.
I have a Foxtech fuselage, which has a special mount for determining the CG. I decided to check if it was installed correctly. I found a special program for determining the MAC. I found out that the MAC of my wing should be located 17 mm back. It turns out that, using the fuselage manufacturer’s settings, I always installed a more forward CG, as you said earlier. Now I made new holes to check the CG. I will make a flight soon and report the results. Thank you.
Your aircraft descends rapidly at 16 m/s. When Q assist is disabled, it causes a sudden drop. Therefore, the Q assist transition point should be adjusted.
