Hi All,
I am wondering if anyone ever tried to do a VTail config for APM and how difficult it would be to just implement what is already in MultiWii ?
Let’s talk about it…
Eric Nantel - DiaLFonZo
Hi All,
You are talking about multicopters, right?
Nice frame! If you make a very light weight one in let’s say 80-90cm class which can accommodate 15-18" props and then a few details for improving camera and battery mount, I might get interested .
Or a similarly large light weight Y6 frame.
Edit: And pancake-compatible motor mounts.
Send a couple of frames to devs and it will be there if its not already
There is a 400mm and a 500mm version to date…
But there will be a bigger one …
Here is the MultiWii sketch i use right now and it work real good.
I would like to try an APM with similar setup mixing
