Videolink & Parameter communication problem QGC android app to 3DR Solo with AC 4.5.3
Hi, I sometimes have problems getting video and always have problems controlling the GoPro on 3DR Solo with OpenSolo 4 and AC 4_5_3. Start/Stop recording never works. Can someone help? I have tested Daily builds, 64bit stable and 32bit stable versions on Android. Display video on the 32bit / 64bit V4.4.3 My phone uses Android 14, it’s a Motorola. I connect with UDP to the drone’s WiFi named Sololink. The main problem now is the Start/Stop recording never works. The Mavlink Inspector in the QGC show GoPro_Heartbeat is received by GCS. It also mentions the Sololink Gimbal. The Error GoPro not available shows up after a flight ( in QGC and Mission Planner )
How to send Mavlink cmd / suggested Mavlink cmd’s for recording on/off to the vehicle?
Is the old GoPro 3 Black implemented in Ap_Camera..? Do I need a 3+ Black? If I start the recording pushing the switch on camera a recording message shows up on screen (I can live with this also). If I start the recording pushing the switch on screen the error “Gopro Not Available” pops up.
Solved, using a Gopro 4 Black and latest AC.
[16:58:35.092] Info: ArduCopter V4.7.0-dev (11400f70)
[16:58:35.094] Info: ChibiOS: c6d0293e
[16:58:35.095] Info: CubeSolo 00520022 32355105 34393433
[16:58:35.171] Info: IOMCU: 420 1001 411FC231
[16:58:35.172] Info: RCOut: PWM:1-14
[16:58:35.173] Info: IMU0: fast sampling enabled 8.0kHz/1.0kHz
[16:58:35.181] Info: Frame: QUAD/X[16:58:35.092] Info: ArduCopter V4.7.0-dev (11400f70)
