The highest peak was 24 (VibeZ), X and Y peaked around 23 a time or two. Winds were sustained at about 8mph during the flight (100 feet AGL, Several waypoints mission in a park).
All three seem to average around 15 to 18 most of the time with some periods averaging around 8 to 12.
It also depends on the prop size and IMU.
On some of my microcopters (3" props) vibes about 5 are too much. I get vibration compensation and ekf errors. All the symptoms of extremely high vibes on larger copters. 5" props don’t seem to like vibes over about 15.
It is a 500mm quad… Originally tuned with 1045 polymer props, but just recently installed 1147 CF/polymer props, which are very rigid compared to the other set. Really did make a big difference in reducing prop noise and the .4 of added thrust:weight helps, too.
