Can anyone explain this? I think I should just replace the servo…
Changing the servo might help
Do let us know how it turned out?
I’ve been researching this more, some say its a power supply problem, some say its a sensor problem. I can’t say this is a power problem as both of these servo’s run off the same power distribution board, I’m going with bad sensor and just replacing it. That will tell me a lot.
Do let us know how it turned out.
Regards,
Shubham Thakur
I had the same issue on another machine and it was the Servo.
Or at least replacing the servo solved it.
I never figured out what was wrong with the servo but replacing it solved the problem. So, faulty servo right from the manufacturer.
