Velocity control go straight with Pitch Angle
def send_movement_command_XYA(velocity_x, velocity_y, altitude):
global vehicle
print("Sending XYZ movement command with v_x(forward/backward): %f v_y(right/left): %f " % (velocity_x,velocity_y))
msg = vehicle.message_factory.set_position_target_local_ned_encode(
    0,
    0, 0,
    mavutil.mavlink.MAV_FRAME_BODY_NED,  #relative to drone heading pos relative to EKF origin
    0b0000111111100011, #ignore velocity z and other pos arguments
    0, 0, altitude,
    velocity_x, velocity_y, 0,
    0, 0, 0,
    0, 0)
vehicle.send_mavlink(msg)
I have a problem with this code when we fly with this command, I need advice about the time sleep for the perfect fit to be responsible!
EXP:
global vehicle
    0,
    0, 0,
    0, 0, altitude,
    0, 0, 0,
    0, 0)
for x in range(0,1):
    time.sleep(0.5)
I try to use the time sleep with 0.5, the quadcopter not respond and have vibration hover. It not go straight with pitch angle that I need.
Thanks for help!
