Har dee har har.
I meant it doesn’t work on MY installation in the mission plan. I’m aware that it’s SUPPOSED to, else it wouldn’t be an option.
I’m attempting to troubleshoot here. (Not that I don’t truly appreciate the time you’re putting in, thank you for that, and for the willingness to help, but c’mon now…) ; )
(Side note: I love the Lost In Space avatar! Danger Will Robinson!)
There’s obviously something amiss with my installation of the software. Or maybe this is possibly a software/version issue. I think I’ll try it from an Ubuntu machine next and see what happens (am currently on Windows 10).
What I’ve found so far: I CANNOT make a plan or load one before I arm/take off in simulator.
If I do, the drone will not arm in ANY mode.
I’m following the instructions scrupulously, going so far as to find 4 different YouTube videos and go click-for-click with whomever’s doing it.
In my case it does not work.
WHAT DOES WORK:
I have to go into the simulator, put it in loiter, take off, let it hover, and THEN go create/load a plan, write it to the drone, and start the mission. This is the only order that works. SOMETIMES I can arm it, then make/load a plan and write it, and start the mission, but I HAVE to have it armed (and usually aloft) before I can touch the plan screen.
If I make a plan at all (or load one) before I try to arm it or take off, then arming it fails utterly. In Auto, Loiter, Stabilize, etc. - It will not arm. When this happens I can no longer manually take off either. I have to restart the software entirely.
In short: Unless I’m missing something that nobody’s thought of, (and I’d legitimately love it if that was the case) I think there might be an issue with my installation, and I can’t currently troubleshoot that until I get into my office.
Note: Not that I think I can’t be wrong about something - in fact I’m hoping it’s something small and silly I’m missing, but as a programmer of close to 30 years who’s worked very closely with a lot of people who don’t listen to instructions, I can assure you I’ve carefully tried to follow several very detailed sets of instructions before asking. I’m not just throwing up my hands and griping when it doesn’t automagically work.
So the update of the original problem as stated seems to be: I have to arm (and take off manually for more consistent success) in the simulation screen before doing anything on the planning screen, or I cannot arm the drone at all.
