I have just built a new small V-Tail,on the bench testing there appears plent of elevator and ruder in manual but in the FBW modes there is hardly any elevator movement is there a parameter to increase this please,many thanks in advance
Hi @MartyMcFly,
I think it is PID of the Pitch. You can try increase the P gain of the Pitch parameter about 0.1 to 0.5 and see the change. But be careful, if too big , oscillation may occur…
thank you for that Tony will give it a try after doggie walk
Hi Tony that worked a treat,thank you so much for that
