Hey, I want to control an electromagnet with pixracer. I will use S8050 NPN transistor(I gave the data sheet below). How should I wire and which resistor should I use I prepared a chart. I added it below. Can you please control it? Is it correct? Thanks.
https://www.mouser.com/datasheet/2/149/SS8050-117753.pdf
I shared this post but nobody saw it. anyone help
The current at the output can reach around 15 mA; check processor specifications.
Place a diode in parallel with the relay coil (anode to positive).
