I am using a optical flow sensor, PX4Flow for x,y stabilisation. The PX4Flow has a sonar attached as well. I am also using a Maxbotix 1240 EZ4 sonar in the quad for height measurement.
I am using Mission Planner and APM 3.5.5. When I am using only the sonar, everything is working and I am able to do altitude hold. But, when I connect my PX4Flow to the Pixhawk, I am getting errors showing on the Mission Planner. Errors: Post vert variance, EKF primary changed. The data in sonarrange is fluctuating going from 20 cm to 6.2 m suddenly even when quad is stable.
Is it because of the interference between of the 2 sonars? How to use both of them?
I am kind of reluctant to buy a light-based rangefinder due to high cost. Any suggestions?
Hello
Answering your question of any suggestion and respecting the opinion of the ppoirier teacher.
I recently came using a TFmini LIDAR and how SONAR works very well and is very accurate
How to disable the PX4Flow sonar so that the PX4Flow uses the external sonar? I could not find the documentation for it.
Also, altitude hold was quiet stable with the sonar, maybe because of using it in indoor environment. @ppoirier
You have to physically remove it (disconnect or unsolder) from the PX4FLOW
Yes the TFMINI is a good alternative beacause its in the same price range and can be uses on serial device type or I2C witj this add-on : How to make the TFMINI rangefinder talk I2C
