Truth_T
(Truth)
1
Hello.
I want to make plugins that can write log on OneDrive or GoogleDrive after arming and disarming.
but, it should use external library for this.
because I couldn’t build mission planner because of dotnet version problem,
I just program plugin file just with one .cs file.
is there way of using external library on plugins?
using Microsoft.Graph;
using Microsoft.Identity.Client;
Truth_T
(Truth)
2
Because It is easy to deploy plugins if I didn’t build it,
I included dll files as external libraries in the same folder.
Is it impossible to include Microsoft Graph library without building…?
Eosbandi
(Andras Schaffer)
3
yes it is impossible. If you want to use NuGet libs or use more than one source file, resources etc. You have to use compiled dll
