I would like to use the momentary switch (SH on Taranis X9D Plus) to set the flight mode to RTL. Now, I thought I had done that but it appears to not work.
It’s probably best just to look at my screenshots:
Aim is to get logical switch L07 set from a momentary flick of the spring-loaded switch SH. I then make L07 cause the appropriate special function to set RTL mode. Note that SF1-6 work fine and as expected.
Yes, I see that now. I’ll play around with it some more. I don’t typically use Special Function overides for mode switching but as we know there is usually more ways than one to do it in OpenTx.
