or 750µs rudder servo.
500 - 750 - 1000 is outside of recommended setting for Ardupilot.
would this be a problem?
If you set the values first in the full parameter list then it will work. The heli-setup page or the servo page will block PWM values below 800 until you manually set the parameters.
