Use Sonar/RangeFinder & Optical Flow Sensor at the same time
I had a question about using the px4flow w/sonar. In mp, optical flow and sonar are two different hardware options. if i only have the px4flow w/sonar do i only need to enable optical flow? what about sonar/rangefinder? do i need to set that as well?
also if i use the px4flow w/sonar and a stand alone sonar, would i enable both optical flow and sonar/rangefinder? is this supported or should i use the px4flow w/out sonar and two stand alone sonar modules.
thanks
I just got my PX4 optical flow camera module with sonar installed. Controller is Pixhawk. But I had problem even at the first stage, that is loading the firmware to the camera module, even though I followed all the procedure as listed here :–
pixhawk.org/users/px4flow_windows_driver
I tried the firmware from 2 different sources :–
  1. pixhawk.org/_media/downloads/px … rivers.zip
  2. ardupilot.com/downloads/?did=118
    Both do not work, I tried on Win 8.1 and Win Vista with same result.
When I connected the module to the Qgroundcontrol, the module can be identified. But when I hooked it up to Pixhawk I2C port, the camera module has no LED light up. I assume the firmware is not loaded. Connecting the module to Qgroundcontrol is for UPDATING the firmware, not loading the 1st firmware, I believe.
Did you install the PX4 flow camera without problem ? Pls share your experience.
did you manage working them both at the same time?
Ze por favor näo ponhas a mesma pergunta em multiplas threads do forum!
