Hi everyone,
What is the best way to copy/save the “OSD Layout” from a flight controller and use it on another one?
P.S. The flight controllers are the same.
Hi everyone,
I exported the config file, then remove everything except
OSD_XXXX
OSDX_XXXX
MSP_OPTIONS,4
MSP_OSD_NCELLS,4
RC_OPTIONS,288
In my case I have 3 OSD enabled so the OSDX is OSD1_XXX , OSD2_XXX and OSD3_XXX
and I always after booting and doing the basic configuration of flight controller I use the compare parameters of mission planner and open my osd_param files and apply the file - I had to to 3 times at least.
I think setting up the OSD parameters by hand should be easier! :))
By the way, I appreciate your instruction.
in true, it’s more easyer than appear
just configure the first one and generate the param file, open in an text editor and remove everything except the lines. I’m attaching my sample osd file as example.
osd_padrao.param (10.1 KB)
