Hi, I pretended to use my RC radio connected with USB as a joystick for SITL, is that possible?
In case is incopatible, I would appreciate an answer on why, to understand it.
Besides, why cant you calibrate the RC radio in the same way (directly by USB, COM port).
Any insight is appreciated. thanks.
This is easily done if you have a Flight Controller running Betaflight. This is my Simulator hardware. The cheapest F4 board and an Rx (any RC sysyem will work). There is a CLI command in Betaflight where this will look like a Joystick.
