hello.
I have a two question. Firstly, I will explain my set up.
I physically set up bicopter for indoor test but using hexacopter software(attached 2 propellers with opposite directions) for my experiment. The vehicle is attached to ground rail, allowing it to move on a slide without changes in altitude. The slide moves in one direction. I am using Pixhawk Orange Cube and an Optical Flow sensor, which I have calibrated. My goal is for the vehicle to hold its position regardless of external forces. I followed this link, and I am confident that I have set the parameters correctly.
Here are my questions:
Upon taking off in Stabilized mode and transitioning to Position hold or Loiter mode, the drone automatically switches to lading mode and shuts down. I don’t why.
After taking off in loiter mode, when I pushed the slide, it does not return to origin position.
Any insights or suggestions would be greatly appreciated.
Thank you.
