I have an issue with avoidance since 4.0 version.
When avoidance is activated, whatever flight mode, avoidance is not stable. In fact, the lidar (upward facing) save the correct centimetric measurement but the drone oscillates up and down (about 20-30cm). I want to correct that but I have no idea how… The goal is to delete or reduce the oscillations.
I don’t have GPS and I have only one lidar upward facing.
Is there anybody else with the same issue? Is it possible to delete or reduce it ?
As everyone is trying to tell you, without the .bin file from a flight showing the problem there is little we can do but point you to the areas of information that we all had to read and digest and learn from.
If you want the benefit from our learning then post a .bin file from the flight controller and you will find people willing to help.
Hello my man…nice to meet you all
I want quest about setup upward facing lidar
I’m using Lidar liter v3, in orientation forward facing lidar, the object avoidance can work
but if i’m setup orientation upward facing, there massage Prearm check proximity sensor
