I recently update mission planner to 1.3.58 and decided to update the firmware on my pixhawk. It’s been about a year since the last time I updated the firmware. After updating my pixhawk when I connect it to my PC and start up mission planner i receive a message stating “failed to create ground station log - won’t log this session”. I’ve googled around but haven’t found a definitive answer. Any thoughts?
you are out of disk space, or the log directory is not valid.
try running as admin
So what is the best way to deal with the space on the memory card?
Ok how should I handle the space because when I go through the terminal and try to clear the logs I keep hearing a sound like the usb devices connecting several times.
try a new usb cable and different usb port. sounds like a power issue.
I have same problem and have replaced cable port and USB hub.
