Hello all,
I want to use an unsupported beacon based non-gps-navigation system (loco positioning system by bitcraze).
Is there a (easy) way to set up and configure the ardupilot for these unsupported systems?
Thank you for your ideas
Hello all,
Hello and Welcome
The Loco Positioning system is based on the Decawave DWM1000 that is similar to Pozyx system. Take a look at the wiki:
Thank you for your reply, I will try it.
Would it be possible to send the position data, which is calculated in the tag, directly to the ardupilot? I have seen that the nooploop system does something similar. Is there a specific protocol which is used or anything?
